Hi,
i replace all bearings on my Gearbox w6mg1.
But on the Rear Gear, i see that 2 spring is broken...
Does Someone know where can i find this Springs ?? News or USED ???
i need them to finish the rebuild
thank's a lot.
Hi,
thank's a lot.
What do you mean rear gear? Reverse on the counter shaft or what is it? I have lots of springs. You can't get them new unless you buy a whole hub and slider. Even then, my brand new 1/2 slider had one that was bent up, lol.
yeah, reverse on the Countershaft
there are 3 balls with 3 springs...
2 are broken on mines...
do you have the 2 or 3 springs USED ??
PM for price ??![]()
I start to reassemble the GEARBOX
i adjust the bearing cage , but cant find the washers "shims" for adjust the preload of all Bearings...
How can i do this ???
Can i make them with a coca-cola Can ??? aluminium is OK or must be in steel ???
thank's for answers![]()
synchro spring OK !! i found them
install OK !!
