OK, I'm slowly collecting parts for my car build. At this rate I may be done in the next 2-3 years. I have a bunch of questions on drivetrain for a 650+whp setup.
If I do a 6 speed transmission with 300M output shaft, Billet end cap, and bellhousing brace will this hold up to hard street driving and launches, or should I be putting the money into a 5speed with billet transfer case? I'd prefer not to swap the car over, but I want to build this thing once and be done.
I guess the real question is what needs to be done to build a reliable 6 speed vs. a reliable 5 speed?
Is there an advantage to going with the MR gears at this HP?
I want to do an SCE front/center/rear diff setup, as I want this car to handle the power the best it can.
Is there much difference between the Quaife front diff and the SCE prepped OBX front diff?
Are there any quaife type rear diffs out there, or is only the clutch type KAAZ that is available?
I see everyone recommends the RPS 6 puck clutch. I'm worried about driveability/durability with a puck type clutch. This will be mostly a street car. Are there any reliable, not noisy, good engagement multi disk clutches out there?
I have/am building this slowly, so I am prepared to put the money into it to get a reliable, fun to drive car.
Thanks!
