Results 1 to 4 of 4
Thread: I need help...
    Jul 2015
    I need help...
    So I have a 94 base 3000gt. About a month ago I pulled my tranny out to change my clutch, I finally got the clutch and put the tranny back in and now I can't for the life of me figure out where this stupid bracket goes. If someone would be so kind as to take a picture of the underside of their car to show me where to put this thing it would be much appreciated. I feel dumb...
    Warner Robins, GA
    Looks like a brace from the bell housing to the engine block. Find the two bolt holes in the bell housing that match two holes in the bracket and the other side to line up with bolt holes on the block. This bracket may go underneath something already installed. You'll get it.
    Jan 2011
    One goes on the front above the starter, one goes on the back above the transfer case. I'd say it's the back one.
    Feb 2013
    California
    Front transmission stay, the lower part (in your pic) faces your engine block, there are two large bolts with a (+) instead of a number, those attach the bracket to the block, then the other side goes to the transmission with 2 bolts with (4 or 7 grade, but def. not the cross + grade).
