Anyone ever run into the issue where launch control doesn't enable? Ill post a screenshot of my rom but the chrome mods are enabled and i have the rpms set for 4500 but if i gas it from a standstill, it just revs to redline.
double check your TPS setting. If your throttle is not above the threshold it won't enable, so if WOT on your specific car is say 89% and the TPS threshold is set to 90%, it'll never work.
I am also plagued by Subaru mode. Tried adjusting the RPM and AFR without luck. Decided to turn it off and run manual. Would like to see a fix for this.
