Results 1 to 3 of 3
Thread: need a micro-amp
    need a micro-amp
    So I was looking at this:
    NVX MVPA4 Micro-V 400W RMS 4-Channel Car Amp with Small Footprint
    Don't suppose anyone here has any experience with these. I'm trying to find an amp that I can fit inside dash, behind the head unit, and this seems to fit the bill. Anyone have any other recommendations that may also work?
    Thanks!
    Feb 2014
    St Louis
    Sub'd for info.
    Sent from my ONE A2005 using Tapatalk
    St.Louis
    Wow, that's a pretty damn small amp, especially if it is able to push that much power. Impressive if it actually pushes that much wattage.
