I've been talking to Robert from Road Race engineering regarding my build. Every bit of advice he has given me has been very beneficial. They have successfull turbocharged a 3.8 Mivec in moderately stock form in their 4th Gen eclipse track car. I've decided to stick to twins for the streetability factor. But due to space constraints I've deviated from the stock locations off the heads. Instead I've chosen to relocate the turbos over the transmission.
The guys at Club4G.org have been more than generous as to lead me the right way also. The engine is now equipped with 3G eclipse cast exhaust manifolds which will act as the base for which i'll be making extensions going to the turbos.
the rear manifold already faces the correct way allowing clearance for a decent sized down pipe.
The Front comes way too close to the Alternatorbut I think I can get away with wrapping or ceramic coating the manifolds and not kill the alternator... HOPEFULLY.
these manifolds ave pretty large runners, I was surprised when I compared them to the 72 parts. The 3G manifolds are also similar to the 4G manifolds.
The flangesand Schedule 10 304Lhave been ordered also. I debated to get the 316 Schedule 10 tube but I didnt see it being cost effective, Maybe if the car lived at 5000+ rpm all the time I would have.
Oil pan has been removed to make my clearances for the transfer case, In the pics you will see where i removed material. The 3.5 Debonair Oil pan in comparison is much easier to work with in my opinion since it already allows for the exhaust to go under the oil pan. While with the Mivec in its current orientation, won't allow me to do that very easily. It can be done, but not easily.
The motor is a 4 bolt none the less, and I might as well throw a 120k on it for safe measures before I really put it together.
I also am going the Single turbo route for the sake of simplicity. The turbo as of now is Top secret lol some of you that have lived long enough to survive ABBA and the Bee Gees may recognize the turbo when I post pics of i
