I could have run the lines straight through a check valve to the catch can, but I wanted to maintain the connection between the front and rear valve covers.
1995 Dodge Stealth R/T Turbo
But if you run your check valves with the flow they would still be connected. On that topic, wouldn't the PCV and small Krank vent do that already negating the need for check valves there?
If I ran both the driver's side lines to a catch can, I'd have closed system, and it wouldn't allow any pressure off. Unless it was the type of can with an outlet for air, but then I'd have a check valve flowing air into, but not out of the catch can on both sides, but that wouldn't allow any transfer of air between the two valve covers.
The smaller Krank vent and OEM PCV valve are both allowing flow into, but not out of, the lower intake manifold. The Krank vent is there to make sure the PCV valve doesn't leak, and the OEM PCV valve prevents the Krank vent from flowing too much air into the intake manifold. I'm hoping I'm making sense to you, because we don't seem to be on the same page here.
