Results 1 to 10 of 13
Thread: How To Set Up Your PCV
    Feb 2011
    Scottsbluff, NE
    My idea for this thread is for members to post up their PCV set up and experiences with the multitude of options there are.
    I have tried several different set ups with my build trying to find the one that works best and I think I finally have a set up that produces no smoke due to crankcase ventilation. I have tried with and without Krank vents, with and without the OEM PCV valve, and open atmosphere. I also have experience with making a PCV set up work for high boost (up to 30psi).
    When I bought my car, it had Krank vents installed (both of them) and it did not smoke at idle or cruise, but when I would be on the throttle it would smoke considerably. Part of the reasoning for that I'm sure was due to blown turbos and a blown motor, but that's what I started with. Lesson learned there is that Krank vents are actually quite effective at creating vacuum in the crankcase which can help keep your car from smoking the majority of the time, even when there are other problems that would normally produce smoking.
    After I did my build I set it up with the front Krank vent left the rear off because I had read on the forums that it created a restriction and could cause smoking. I also did not have an OEM PCV valve on the car. That set up did not smoke under throttle but would smoke after letting off the throttle coming from WOT. The reason why was likely due to the Krank vent allowing too much air to be sucked into the lower intake manifold without the OEM PCV valve and sucking some oil with it as well. Ray advised me to either install the rear Krank vent or put on the OEM PCV valve.
    I installed the rear Krank vent and then had problems with the car smoking at WOT, as is commonly seen because the rear Krank vent is enough of restriction to cause smoking at higher boost levels.
    At that point I tried removing all valves from the set up and just venting to atmosphere (with an awesome temporary Mountain Dew bottle catch can). With that set up there was minimal smoking at idle and during accel, but there was some smoke after closing the throttle and considerable smoke when under high vacuum during decel (like when going down a hill in gear). My guess is that my VSS would allow some oil through at high vacuum in the intake plenum (over 20 inHg vacuum).
    After that I tried going back to the Krank vents to help out when there was high vacuum in the intake manifold. I put the OEM PCV valve back in to ensure that not too much air was going into the intake manifold after letting off the throttle to keep any potential oil from getting sucked into the engine. That set up worked beautifully while I had the car at wastegate boost (12psi).
    Unfortunately when I cranked the boost back up to 30 psi, it smoked considerably at WOT (see earlier set up with the rear Krank vent restriction). So my plan to counteract that was to put a pair of 1/2" tees on the driver side PCV line that goes between the two valve covers with a one-way brake check valve at the end of each tee. The check valves prevent air from entering the engine which still allows me to pull vacuum in the crank case when off the throttle and they allow more air out during WOT to account for the increased blow-by inherent in high boost set ups. Ideally I will route those two check valves to a catch can, but my temporary catch can gathered virtually no oil for the several months I had it on the car.
    tl;dr, I'm running an OEM PCV valve, both Krank vents (smaller one between the PCV and the lower intake manifold, larger one between the rear valve cover and intake splitter), and a pair of tees with check valves on the driver side PCV hose between the two valve covers. This set up has allowed me to hit 30 psi with no smoking at all.
    I thought I would share for others that are wondering just how to set up their PCV with all the different info out there on what set-ups to use. I welcome anyone else's set up and experience with their PCV set ups.
    1995 Dodge Stealth R/T Turbo
    Feb 2011
    Scottsbluff, NE
    I've drawn this completely awesome diagram to help visually explain specifically what my current set up is.
    Quote Originally Posted by DK77 View Post
    Attachment 8403
    Awesome = nonfunctional, D.
    Fix it, cuz I want to see it!
    VR-3747 :D Not Verified
    Dayton Ohio
    Your attachment doesn't work
    All I did was run the small krank vent in series the the pcv valve. You can barely even see it.
    Feb 2011
    Scottsbluff, NE
    Dangit, it worked last night when posted it. FIXED
    That is an option. The reason I wanted to keep the rear Krank vent was to have vacuum in the crank case off throttle. I've a hunch my valve stem seals are leaking slightly and having vacuum in the crank case helps to mask that.
    Question: I was under the impression that the reason for running the crank vent was that the oem pcv could not flow enough. Or was it it leaked under boost?
    One fix at a time verified
    Kansas
    All I run is the small krank vent with a barn in place of the OEM pcv valve. No issues up to 35 psi with smoking. My motor is in good shape with newer VSS even though most everything else is original.
    Matt Monett recommends running something similar to what you have with check valves coming off the driver side vacuum line T'ed into a catch can. Look up some pictures of his race car.
    Feb 2011
    Scottsbluff, NE
    The smaller Krank vent is to prevent boost from entering the crank case since the OEM PCV valve will leak at higher boost.
    I was running Both krank vents with no PCV, I discovered that I had a noise similar to a throwout bearing going bad. But I discovered that when the car was running, I could remove the oil cap and the noise went away. After talking with Von about it, he advised that I put an OEM PCV back in the loop because I was getting too much vacuum. I put the OEM PCV back in and my noise is gone.
    Will look into a catch can when I get into the land of hi-boost.
    I have to ask why the T's, why not route the line:
    Front bank to catch can and catch can to rear bank?
