Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: New European record
  1. #31
    Basingstoke UK
    Working!
    André
  2. #32
    Feb 2012
    Aberdeen Scotland
    That's good, I've seen a few damaged. ...
  3. #33
    I've seen this happen before too, always wondered if someone would make a lower timing belt cover out of metal.
  4. #34
    Quote Originally Posted by Permanent grin View Post
    There would be the exact same number of shift points and to my knowledge the 5 speed gearbox is not stronger or more durable than the JDM 6 speed. You need to remember that I am only at wastegate and will be adding another bar of boost, so the terminal speed will be vastly different, high 160's minimum. The TC gears yes, although I am hoping iI have a working solution now.
    To illustrate my thinking, these are the approximate maximum speeds per gear at 8500 rpm. Bear in mind that as well as the 1/4 this car will also do the 1km once a year too.
    5 speed
    1st - 52
    2nd - 92
    3rd - 143
    4th - 192
    5th - 238
    JDM 6 speed
    1st - 46
    2nd - 78
    3rd - 130
    4th - 178
    5th - 220
    6th - 277
    My 6 speed
    1st - 63
    2nd - 90
    3rd - 130
    4th - 178
    5th - 220
    6th - 277
    André
    So what was done that your speed at 1st and second are different?
  5. #35
    dogbox
  6. #36
    Basingstoke UK
    I had new gears made for the dog box.
    André
  7. #37
    André
    SCE's or another's? And just to confirm you listed your speeds in KMH correct?
  8. #38
    Basingstoke UK
    Elite Racing Transmission with my custom design.
    André
