Results 1 to 9 of 9
Thread: 91 RT/TT Revival Thread
    Shop picked up a 91 RT/TT today. Was just rebuilt but the 3rd main was installed upside down blocking the oil galley and it spun.
    Was a bit dark after we got it home but I started tearing it down anyways. About an hour of work here if that. I'll have the engine out and torn down tomorrow.
    Found some oil in the y pipe, not a huge deal as the turbos are getting rebuilt or upgraded anyways. Also has an entire book documenting whats been done. Rebuilt trans, new clutch, 120k kit, and oil pump. All done less than 1000 miles ago. And I found some goodies I didn't expect like a boost controller and a greddy BOV.
    Will post more progress tomorrow night, Hopefully i'll have the block off to the machine shop this week!
    Madison Heights, Mi
    :like:
    Shop truck broke so we were working on that, washed it up a bit tho to see how the paint is since it was so dirty.
    Moda R6's are pretty nice, brand new Duro Evo's on them as well.
    Paints not too bad, should clay bar up nice and the front bumper is just primer
    oooh, whats this? Gonna be fun figuring out how all the wiring goes to this.
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    Hidden turbo timer?
    It has an electronic boost controller on the inside of the engine bay, thinking maybe that's the control for it? I'll check it out more tomorrow.
    Got a bit of time to work on this today and made good progress.
    Kevlar timing belt and solid tensioner from Ninja Performance. I thought I seen these in the pile of receipts This find is turning out pretty good.
    I can see why they rebuilt the engine in the first place, it definitely snapped a rod at one point.
    The cap doesn't match this rod. Not even close even tho they are both stamped with a two, not sure what happened when it was rebuilt last month but I can see why it blew up, just poor work all around.
    This is what happens to your bearings when you use the wrong caps. I don't have a picture of the bearing that was flipped but it was almost ground entirely down to the crank, either way this thing was going to die with such poor work man ship.
    Two number 8 caps, I seriously have no clue what was going on here.
    I have a rebuilt NA short block with less than 2000 miles that I'm going to use for this, just going to swap the pistons and glaze break the cylinders and it should be good to go. I have done some research and Ninja Perfomance used a NA block and did many 11 second passes despite it not having oilers. The forged crank from the second gen NA will be a nice upgrade as well. I'll be pulling this apart and inspecting it tomorrow.
    Hopefully this weekend we can be turning the key. Just depends on how quick the machine shops gets the turbos, oil pump, and everything else that's touched oil hot tanked and cleaned.
    Sent from my Nexus 6 using Tapatalk
    Anyone know what kind of pistons these are?
    They are .035 over and seem stockish. Are they forged?
    So much for getting it running this weekend. TT block and forged crank are off to the machine shop.
    Got the block and crank back. Realized the stays for the thrust bearing have been machined away and now there are press pins to hold the thrust bearings on. So I have to drill and ream holes in the thrust bearings. I'm also considering using the old ones. I put them in and checked the clearance and they are within tolerance. What do you guys think?
    Dec 2005
    Williamsport, PA
    Take a picture of the side and top of the piston.
