Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: most reliable/ accurate oil pressure gauge
    Mar 2011
    oh five
    stop asking, texas IS a shiny penny.
    is there a particular series of greddy that is viewed as very good?
    here's a new question:
    do any of these "trusted" gauge companies have astounding customer service records? like to the point of replacing gauges after over a year of use?
    y, what autometer gauges are the very good ones?
    _isiah
    _isiah
    Is your engine still giving problems?
    Problem free sitting on the stand! WOrk begins this weekend...
    Did you ever find a smoking gun?
  4. #24
    Other than the grooves in a 3k mile oil pump, no.
  5. #25
    Jan 2012
    Arizona
    I run Tanabe VLS OLED, about 1 year so far, is accurate and and reliable so far. My only gripe about Tanabe is none of their gauges have a datalogging output wire.
    What you want to look for, is a good gauge will usually have a 3 wire sensor, which is a powered and more accurate sensor than a 2 wire typical resistor type sending unit which only tells you the resistance value in relation to ground.
    1993 VR-4
    Engine -
    IPS catback
    Custom Downpipe
    Custom FMIC kit
    Suspension -
    BC Racing coilovers
    Solid / Poly busings
  6. #26
    I've never had problems with their mechanicals. *shrug*
    +1. All of my cars use a mechanical oil pressure gauge. Its simple, no electronics, no wiring, not much can go wrong. Heck after i rebuilt my VR4s motor back in 09 I was paranoid about oil pressure on first startup. I installed a cheap-o sunpro mechanical oil pressure gauge just to have some piece of mind during my first start but after that initial start i started to like it and just left it in the car. Its been nearly 7 years and that mechanical cheep-o gauge is still reproducible and never given me any issues. Its not fancy, it cant output a signal, and isnt digital but its never failed me.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
