Moved up to a Chrome ECU so my old tuning package is up for sale. Selling this as a complete kit. Not going to separate at this time.
Looking to get $400 shipped within the US for the entire package OBO.
SOLD
***Update***
I ended up finding the other harness for injector/timing control that I thought I threw out. I also found an old boomslang harness. The boomslang is pretty beat up and I never used it but it is just wires so you can fix anything that is already cut on it. it was originally wired for the Emanage so the wire colors are still there to hook it back up. Added a pic of the harnesses.
Kit includes the following:
Emanage blue
-1.49 firmware installed
-Main wiring harness already set up for 3S
-USB Com Cable that I build - Drivers included
Ran this kit for many years and never had any issues with it. I have all of the software, Manuals, Drivers, Support Tool and Firmware for this kit that will be included. Download link provided after payment is made for all of the software.
Scanmaster 3
-Plugs directly into ODB1 port.
- External output to serial to connect to logger.
-Allows monitoring of OS and Knock read directly from ECU
-Tons of options for this unit. More found here - Stealth 316 - Scanmaster 3 Installation
**Note - Only issue is that sometimes the display just shows 8. A quick smack on top of the unit fixes the issue. I opened it up and not seeing any loose connections or anything wrong so not sure what causes the funky display issue. I got this from Forest Gump years ago and it did the same thing for him. It does it randomly but other than that it works great.
Palm M130
-Includes Hot Doc base to sync and charge
-Serial to sync cable - Use to log or sync
-Serial to palm connector - Use to log.
-ODB1 to serial - Plug this directly into the OBD1 port to log.
-Expandable Keyboard used to type into the palm. Good to make notes when out tuning.
**Note - I don't have any of the Palm Software or MMCD software. It is easily downloadable from various places all over the internet.
