Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: Small K&N cone filters: How well do they flow?
  1. #41
    I think the easiest way to test the filters would be to dyno the car with the filters, then again without the filters. I know ive done 518whp with those and i think (but could be very wrong) that eric with the black dr750 car did 600+ awhp while running the same dejon intake.
    Once i went to the DR1000s i was also worried about the filters and tubing causing a restriction. I ended up buying the following from cxracing.
    PIP300-90-2 3" Inch OD 90 Degree Universal Aluminum Intercooler Intake Pipe $39.99
    PIP300-45 3" 45 Degree Bend Aluminum Pipe, 2.0mm Thick Bend, 18" Length $15.00
    SH300R275-3BK-76 3"-2.75" Black Silicon hose reducer for Intercooler pipe $8.00
    SH300R275-4BK-90-85 3"-2.75" 90 Degree Eblow Black Silicon hose reducer 4 layers coupler $15.00
    (x2) CLM300-T 3" T-bolt clamp Supercharger Turbo Intercooler exhaust $4.00
    (x2) CLM275-T 2.75" T-bolt clamp Supercharger Turbo Intercooler exhaust$4.00
    The grand total was only $105.
    Dejon vs T3/T4 DR1000.
    EDIT: I also used the KN Filter PN RE-0910 they are 8" long 5" wide and 3" hole
    http://www.summitracing.com/parts/knn-re-0910
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
  2. #42
    Nov 2011
    That came out nice, I ended up with way more silicone then I wanted for mine; I ran out of space and drive to buy any more aluminum pipe. I think I'm seeing on v1, v2 will be more like yours.
    I'll try to get some pics up in a bit.
  3. #43
    I cant breath!
  4. #44
    August 2010
    Chicago
    RE- 0870 is the one on top that got replaced and RF-1040 is the one on the bottom. Rated at over 1000cfm..made for turbo diesel trucks. RE-0870 is commonly run with the ARC2 setups. Not my picture, just posting.
    I'm looking to replace my dual filters with a bubble and the largest filter I can fit in the area.
    34XXlbs..
  5. #45
    August 2010
    Chicago
    another pic...
  6. The Following User Says Thank You to NOMIEZVR4 For This Useful Post:
