'92 Dodge Stealth SOHC - 3SX Adjustable Camber & Toe Arms, Eibach Springs, KYB Struts, 3SX Steel Braided Brake Lines, Stillen Brake Pads on Stillen Cross-Drilled Rotors, 3SX Steel Braided Clutch Line, 3SX Lightweight Aluminum Crank Pulley w/ Gatorback Belts, 65mm Big-Bore Throttle Body w/ Half-Shaft Mod, ARP Head Studs, 3SX Poly Motor Mounts, 3SX Short-Throw Shifter w/ Solid Shifter Bushings, Single TD05H 20G, FMIC, FMOC, Hotwired Walbro 255, 525cc Precision Injectors, 3SX underhood fuel kit w/ Custom SOHC Fuel Loop, Custom Ceramic Coated Headers and Turbo Downpipe, RT High-Flow Cat, Custom Stainless 2.5" Cat-Back w/ Flowmaster 40, Spec Stage 3 Clutch, Fidanza Light Weight Flywheel, Various GM Sensors, Innovate LC-1 Wideband, Tuned with MAPECU 2.
