Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Evap delete
    Evap delete
    I realize evap delete is mostly something the TT guys do, but in the process of pulling crap out of the engine bay for cleaning things up for paint I realized just how crappy the bracket that holds the evap canister looked. Even after sandblasting it and painting it, it still looks far from good so I started thinking about just doing the evap delete. For some reason there isn't a lot of info about just how to do it, but it seems straight forward.
    I am guessing all I really need to do is not put the canister back since it is already out, then decide if I want to cap the line, or leave it open. Have also read posts where people removed the entire hardline back to the tank and either capped for vented there. What do you recommend based on your experiences?
    My main question though is what is done with the purge solenoid? Is it removed along with the canister since it is no longer needed and will is cause me a CEL?
    Dayton, Ohio
    Wish I could help you Brian, but I have no clue....
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
    Oct 2011
    Sundsvall, Sweden
    I removed the canister, solenoid and all the related vacuum pipes. Didn't cause any cel with the eurospec stock ECU I was running at the time. I left the line open and just stoved it away underneath the coolant overflow bottle.
    Thanks, I didn't figure it would throw a CEL, at least on pre OBDII cars, but needed to make sure.
    I actually have the line removed all the way back to where it connects at the firewall by the fuel lines and rear brake lines. I'm not going to put that line and brackets back on.
    I believe the evap hard line goes back to this blue check valve that leads to the top of the fuel tank. At least I think that's a check valve. Leaving the line open will definitely increase the smell of fuel around the car. I'm not sure what the best solution is but let's figure it out
    What if we did something like this?
    Amazon.com: Auto 7 (010-0124) Fuel Tank Breather Filter: Automotive
    I don't know how well it would work. What I was really looking for is a very small charcoal canister that could be mounted back next to the tank somewhere. Could run the vent line to it and leave the other line open. This would greatly cut down on the fuel smell.
    Also was doing some more reading and have read where some old muscle car guys eliminated their evap, plugged the line so to prevent the fuel smell, then used a vented cap to prevent pressure build up.
    Jun 2011
    Sweden, Gothenburg
    wouldn't the fumes still just go through the vented cap?
    could build your own if you cba HowTo-> Rebuild that charcoal canister
    btw I don't remember exactly, the line after the cannister just leads to the PTIP right?
    After searching for universal aftermarket solutions (very little luck), it seems OEM is your best bet. Capping the line causes excessive pressure build up in the tank... a check valved line from the tank to your intake or intercooler piping may create excessive vacuum in the tank and make life harder for your pumps. If the blue thing on top of the tank is really a check valve, then simply using fuel should create a vacuum in the tank... the pump heating the fuel seems to cancel this out and then-some (hence pressure build up when people cap the hard line; seems the pressure gets high enough to launch your gas cap at you and immerse you in fumes when you remove it)... I'm really leaning toward putting a breather filter on the blue check valve and calling it close enough. Just live with the occasional scent.
    Perhaps a check valved line to your intake with a flow restrictor would be perfect. You'd need a pressure sensor in the tank to size the restrictor orifice
    See, that's one thing that had crossed my mind too. My thoughts though led to the possibility of fume build up in the intake and a backfire on start up.
    I too, am considering just dealing with the occasional fumes. Some sort of charcoal filter attached to the check valve at the tank should probably greatly reduce odor though.
    What about a bottle of activated carbon (see amazon)... run the vent line into the bottom of your carbon reservoir and allow it to vent at its own pace. Should maintain nearly atmospheric pressure in-tank but minimize odor.
