Results 1 to 3 of 3
Thread: Timing Setting Question
    Drives a UFO
    Grand Cayman, Cayman Islands
    Hey all,
    My water pump failed about three weeks ago (20K miles on it) and that is why I am doing the 60K service now. I am using the guide from Team3S below:
    http://www.team3s.org/60k.htm
    Now, the procedure seems quite straight forward, but I do not understand why does it call for marking the timing belt? Aren't the cam gears the ones that have the marks (small dots) that need to align with the arrows on the heads? Could anyone elaborate on this? Thank you!
    '95 Mitsubishi GTO AWD ATX - '99 front end conversion, TT conversion (19Ts), Forced Four shift box with paddle shifters, A/A wing, LCDBC, 3" straight piped exhaust with no cats and gutted pre-cats, Custom rear diffuser, HIDs, Carbon fiber steering wheel, 18" Mustang Saleen replicas.
    '92 Dodge Stealth ES - 3KGT body conversion. Sold!
    It calls for marking it if you are reusing it because it wears a certain way and essentially becomes directional. Most people aren't going to reuse their timing belt, so as long as you are doing the same, you can ignore that step.
    Drives a UFO
    Thanks for that info!
