Hello all, I've been working on the car this morning and part of it was to set the base timing with 1st gen CAS setup.
Brown plug grounded, logger disconnected, strobe on lead 1 etc.
At idle the car shows 10dbtdc which is over factory spec by 5 degrees but since runnng meth mix this is benificial to me.
At 3500 rpm the timing retarded to 5 degrees!, surely this is well outside the limit and I can only assume at 7000rpm it will be even worse (couldn't rev that high to check).
So has anyone else reved the car up during base timing adjustment and checked the timing is still locked out at 5 degrees or are my findings normal?. Surely the commanded timing from the ECU will be miles out at higher revs.
I have the option of adding advance back in with the Emanage Ultimate to compensate but would like to hear if anyone else has encountered this issue first of all.
Cheers, Keith.
