3SX Performance Automotive - Mitsubishi 3000GT & Dodge Stealth Parts & Service
THE CRANK PULLEY... or Harmonic Damper if you call it that... Don't let this be you... Regardless of the theories and opinions about which crank pulley to run, we HIGHLY recommend that you remove and replace your very old and tired and worn out stock crank pulley. The rubber between the steel pieces is AT LEAST 15 years old, up to 25+ years old - meaning it's dry rotted. We have heard and seen too many instances of the old stock pulleys failing and causing damage. This particular one took out the engine, flattening all 24 valves requiring an overhaul. 3SX offers brand new OEM pulleys, aftermarket dampened ones, and our popular solid aluminum pulleys in both stock size, underdrive, and even for the SOHC engines! Please do yourself and your engine and your WALLET a favor and replace your old dead stock crank pulley. We have put ALL the crank pulleys we carry ON SALE to help you keep your ride running healthy!
* sales Sales !SALES!*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
The 3SX Crew
