Results 1 to 7 of 7
Thread: Air conditioning idle problem
    Addicted to Crank Not Verified
    Crown Point, IN
    The problem is my car idle drops to about 500-600rpm when I turn on the air conditioning. When I down shift or stop the rpms drop to around 100 and the car sometimes dies. This all started after I changed out a bad AC compressor with a rebuilt unit. BTW. I do have a dashpot on the throttle body.
    As far as running the car without the AC on, the idle is perfect. With all accessories off and the car warmed up, I set the base idle by grounding the test pin and turning the biss to get around 700rpm on mydata logger. When I pull the ground the idle goes up to a little over 800rpm. I further adjusted the biss to get 900 rpm. That is where I like to keep it. I am losing close to 300rpm when I run the AC.
    The ECU is supposed to know when the AC is running and I wonder if it is not getting that signal. I have been going over the circuit drawings, but I have not found anything that says this is how the ECU knows the AC compressor is running. At least with the PS pump, you know how the ECU gets the signal to increase idle speed. Any one here know how the ECU gets the signal from the AC unit?
    Dayton, Ohio
    Have you tested your IAC (simple resistance check that can be found in the manual)?
    Does the idle go up when you turn your steering wheel (it's supposed to..)
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
    Crown Point, IN
    I guess that will be my first check tomorrow morning.
    I actually have a schematic I printed off when I was looking for a harness on my car and if I am reading it right it looks like the signal comes from the magnetic clutch relay.
    You may have one bad coil on your IAC. Ohm it out and see.
    EDIT: I must have gotten distracted and didn't see the 2 replies before mine. LOL
    Crown Point, IN
    I'm finally getting around to posting a reply. The IAC motor tested good, but it was old and I replaced it anyway. I don't have an oscilliscope so I didn't measure the pulses to the IAC. Changing the IAC motor didn't change a thing but I did some adjusments in the decceleration air setting of my SAFCII that stopped the motor from stalling. I noticed that when I let off the accelerator and the RPMS dropped quickly the car went very lean (*I know it is supposed to do this, but when my rpms dip to 200 with no fuel with the AC on the car dies). I am really not familiar with how the decceleration setting works (*it is supposed to be used on a hotwire air flow sensor car) but I set the throttle point to 5% and the two NE adjustment points to 2% and 1% enrichment. Now when I let off the accelerator instead of going lean right away the car stays around a 15.0 AFR. This may not be a perfect fix, but it seems to be working for now. **When I let off the accelerator during normal driving in traffic fuel cut still activates. The deceleration adjustment seems to only kick in when I let off the accelerator and depress the clutch letting the rpms to fall idle rapidly.
    Medford OR
    Your datalogger has a PID in one of the FLAG parameters that tells you if the AC signal is received... Jacking the idle up higher than spec will force the IAC fully closed, and it will never recover fast enough to do it's job.
    You also cannot perform the base idle or base timing procedure with a datalogger hooked up. It's a one or the other situation. (although if it has the function available, you can command base timing with a scan tool/datalogger)
    Full lean on decel is normal, it's called decel fuel cut... Have you checked/set the SAS screw and dashpot setting? Is the TPS adjusted properly?
    Crown Point, IN
    I grounded the base idle connection and used my datalogger as an idle reference and set the base idle to 750 rpm using the BISS. Everything that I have read says not to use your car's rpm gauge as your idle reference. That is why I did it with my MMCD connected. At the 750 rpm setting my car always died when coming to a stop sign in the city not exceeding 30mph withthe AC on. I adjusted my idle to 900rpm with the BISS to compensate butthe car still died. After adding deceleration air compensation, my car no longer dies. Maybe I need to lower the throttle point % a little and the NE correction a little to fine tune, but it is working.
    The dashpot has been adjusted to retard the closing of the butterfly. My first adjustment had the rpms hanging at the last throttle position a little too long. I think it is in a good position now. There is a nice slow decay of rpm when at mid throttle, but it is still kind of quick at 2000rpm and under.
    When I had the dashpot adjusted for a longer delay, I started to get O2 sensor error codes. Maybe becasue of my choice of 25% low throttle and 55% high throttle on my SAFC II set points.
    I am not sure if my MMCD Palm data logger has the A/C PID. My Palm is dying and I just ordered a Hybrid HHH from 3SX (now in stock). I think that will give me a lot more info. It should arrive in a day or two.
