Hey guys. I just swapped on some 2G tt calipers on my car and the rotors I got seem to be too tiny? The brake pad hangs over the outside edge of the rotors too far. I ordered the rotors from R1 concepts for all 4 corners and the rears fit perfectly. I called them up today and asked for the rotor diameters and they said the fronts are 314mm and rear are 296mm. I will measure the fronts when I get home to confirm the 314mm diameter. I had 1G knuckes on my car and I am just curious if the knuckles changed from 1G to 2G?
