+1 on carrier bearings. I had the issue with my VR4 and ended up buying a driveshaft with 75k miles from another member for $150 or so. Once replaced it was perfect again. Sure beat the headache of trying to service it or paying upwards of $1k for a new replacement.
My car was exactly the same - every time I let off the gas, I got a "CLUNK!" from the rear end. I got pretty good at feathering the throttle, lol!
When I replaced the carrier bearings and the rear diff mount bushings, it was like magic. No more clunk! I think that the diff mount bushings had more to do with it, although since I did both at the same time it's hard to say for sure.
Anyway, just get a set of replacement bushings from Mitsu - they're not that expensive. Then, when you have the drive shaft off anyway, support the rear diff with a jack, take off the mounting brackets, and take them to a shop. Have the old bushings pressed out and the new ones in. I can't remember if they have to go in with a particular orientation, they might which is why you don't want to take the old ones out before you're ready to put the new in.
The bushings are pretty easy to have done, much more so than the carrier bearings. If you're going to do the one, definitely do the other at the same time.
I had that too, me it was the slack in the tranny, but before it was rebuilded, I change the DS for a CFDS, and replaced the rear diff (mine had some slack) for an almost new one. It helped a bit, but the new tranny got rid of the slack.
Eric
DR750's, DR stage III heads, DR Boost cooler stage 2, Denso 660cc, TE37SL +273'S Z1, KWv3, Stedebani suspension buschings, SCE 13'' Stoptech, 2G rear brakes, Forged shortblock, 3SX cam gears, SCE racing oil pan, PST CFDS, RPS 6 puck, RPS Flywheel, ETS FMIC, 3'' custom quad tips catback, new leather seats heated, SCE center diff, Quaife, brand new tranny/tcase, Billet casings, Chrome ECU, Swaintech...
