I have recently completed my twin turbo conversion on my Dodge Stealth/3000gt ATX. I got her to the point of starting, idling, reving, and functioning correctly. However, as I went to back out of the garage the car moved only about 3 feet before acting like it was in neutral. In drive the car moves forward with no hesitation. If put in reverse, the car does not move again, and then dies entirely. The engine shuts down completely (no clunks or noises). Im usually unable to start the car for a few days as I have to unplugged the ECU to clear whatever is shutting it down. I pulled codes from both the ECU and the TCU. The Ecu only had one for the rear oxygen sensor (I dont have one) and the TCU had one for the throttle positioning sensor. The car has died like this three times in reverse, no other gears kill her. I installed an end clutch kit and shift kit from import trans, so im going to pull the valve body out to make sure that seal on back (thats needed for reverse) is still there. Any idea what might be going on here? Any help would be appreciated.
UPDATE: Today I pulled the valve body and the o-ring/seal was present, all of the solenoids looked good, and there was no metal flakes or anything present. I also pulled the end clutch and al of that seemed good too. Help?
