1998 $ $6500 obo
Located in Reidsville, NC (near Greensboro)
Text for the fastest response 336-496-7487
Please read this post in its entirety if you are interested.
-Timing belt replaced less than 5k ago (previous owner)
-New Spark Plugs and Wires
-New aftermarket downpipe, cat delete and gutted rear cat (1g downpipe converted to work with 2g)
-Aftermarket Intake Y Pipe
-K&N Airfilter
-Flashable ECU, just buy the flashing tool and ROM
-18" Chrome wheels with good tires, wheels need work (they leak because of chrome peeling)
-17" 1g wheels bad tires
-RPS Pressure plate and street disc
-Clean interior in great shape. Only needs minor stuff. No tears
-Needs glove box mechanism
-Has battery will not hold a charge
-205k on the chassis and engine, engine runs great
-Rebuilt Transmission with new Output shaft, synros and seals. Just installed it and it has an issue that causes it to make a very loud tapping sound. It will need to be disassembled to find out whats wrong with it. It shifts through all the gears just fine. It is for sure the transmission, not the TOB. The rebuilder probably put a gear in wrong, or there is a broken tooth.
-I have the ordinal window sticker and manual
-This car is 1 of 231 ever sold in the US
I have videos of the car running and of the sound the transmission is making.
Cash only! No trades! You will need to trailer this car away.
This is a great opportunity to own a really rare car for a great price. It just needs a little TLC that I can not afford and do not have the time to do.
