Results 1 to 5 of 5
Thread: A/C R12 to R134a conversion help please
    Hi, I want to convert my 1992 VR4 A/C from R12 to R134a and my question is; I know I have to replace the condenser but do I need a later (1994 on) condenser or can I use a new 1991-1993 condenser. I know I have to change my compressor but do I also need to upgrade my rubber hoses?
    Thank you for your help.
    you pretty much don't *have* to change anything but get some adapters from 12 to 134 on the low and hot service ports.
    Its best to also get a can of flush to flush all the old crap and oil out. then put in the specified amount of oil, pull a good vacuum for at least an hour and then 80-85% of the r12 rated poundage in r134
    I was just wondering if the later condensers were a different volume to the earlier ones? I know you have to change all the seals in the system as the R134a oil destroys the R12 seals.
    West Islip, NY
    You also need to change the expansion valve for best 134a performance.
    1991 Dodge Stealth ES
    - Sold
    Sold.
    I have rarely changed any seals that were not leaking to start with.
