Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: chrome help!!
    Never mind, I'm wasting time here.
    ok so i unplug the front o2 and nothing changes at all. idk if thats because periphery0 bit 2 is disabled or if i have a bigger problem?
    unpluging the rear o2 for some reason smoothed out my idle, but made my rear o2 read lean on the rp o2 sensor and 12.5 on the rear feed back trim. . https://www.dropbox.com/s/hduida2yyt...nplug.csv?dl=0 the log starts with the rear o2 unplugged and you can see when i plug it back in it i then unplug the front and nothing changes. they do not appear to be swapped as unplugging the rear only affected the rear.
    whats making the front read -25 when the rear will only go +/-12.5
    sorry if we have a misunderstandings, i just wanna make sure we are on same page and ive just been able to get time for the car.
    You basically are off to a really bad start without both o2s working. There may be a way to get it to work, but it is a LOT easier if you just set the o2s up like stock and go from there.
    Unplugged o2 sensors will make the trims go to +12.5 because that's the max and the ecu thinks its really lean since there is no o2 signal voltage.
    There aren't many drawbacks to running medium sized injectors like you have with chrome, it will work fine, although I still believe people are better off running evo 560s if they meet their power goals, just because the latencies and injector scaling will require a lot less experimentation.
    Thanks for the reply. Do you mean setting up o2's back to stock by disabling the periphery 0 bit 2 back so it runs off both banks?
    And I'm aware itll read +- 12.5 but the front is reading -25, is that because the periphery 0 but 2 is enabled so it's only reading the rear? Or should it still be reading both just making adjustments off the rear?
    I just woulda though it would stop at a +- 12.5 like the rear..?
    We were unplugging them to see if the o2's were backwards which they aren't.
    P.s. Car runs like crap with periphery 0 but 2 disabled.
    JNS Engineering verified
    San Jose, CA
    First things first, O2 not cycling means it's either not wired correctly or sensor is bad. You have to fix this first.
    The other thing it can be is the tune is so far off it can't cycle, but I agree it is usually wiring.
    I lack color... verified
    Aug 1998
    Quote Originally Posted by notstealthy View Post
    Fuel trims don't go to -25.... Are you sure you using the correct Evoscan file?
