Page 14 of 19 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 181
Thread: Widebody VR4 Build
  1. #131
    VR-3747 :D Not Verified
    Dayton Ohio
    Been working on this thing non-stop!
    The car keeps overheating which is frustrating. I felt my bottom radiator hose and it was cold while the top one was hot... points to the thermostat not opening. I took it out last night and it opened fine when I boiled it so I know it's not that. I drilled 4 holes in it to promote some coolant flow regardless... I'm confident it will help but it's obviously a bandaid. Frustrating. I'm thinking my water pump is a POS. I'll replace it if and when the Fluidampr group buy happens. I am truly stumped as to why (with a funnel in the opening of the water neck) the coolant level doesn't go down (due to the thermostat opening). I'm open to suggestions on this.
    I made 2 videos to show running conditions. Oil pressure looks fantastic (just using stock gauge... I will eventually put a sandwich plate on it and run another gauge), but E85 is proving to be a bit of a butthole. Just doesn't like to start and run when it's cold. I'll keep messing with the tune (only 4 flashes to this point and they've all been focused around idle AFR's).
    Idle vid (taken before I messed with the thermostat)
    Anti-lag test
    Going to replace the fuel pumps and (hopefully) fix the fuel gauge all in one tonight. Still have lots of little things I'd like to get done, but I suspect a test drive sometime next week.
  2. #132
    I bet there was a decent size air bubble by the thermostat and it wasn't seeing the hot water and therefore not opening...
    Dayton Ohio
    How do I get rid of said air bubble? I burped the system a lot, but no dice
  4. #134
    Dayton Ohio
    videos fixed. I know they weren't working.
  5. #135
    Easiest is drilling some holes in the t-stat and you'll get some flow so there's no air bubble there, which you did. Have you run it since?
  6. #136
    Dayton Ohio
    Just once. I unplugged both fans when I did to see if the thermostat would open up and I could watch the level drop... never happened... I really think my water pump is shit, but we'll see. I'll definitely keep an eye on it
  7. #137
    Think it's worth a new WP either way, Gnate.
    Sounds gnarly, I like it.
  8. The Following User Says Thank You to j2k4 For This Useful Post:
  9. #138
    Dayton Ohio
    Still chipping away at things. Test drive tomorrow!
  10. #139
    Dayton Ohio
    Got it on the ground yesterday!
    And took it around the block!
    No leaks, pretty uneventful (which is good). Clutch is surprisingly tame (compared to my spec stage 5), I can only imagine if I didn't have 2 race plates, I'll bet it wouldn't be bad at all!
    Tune is way off and a few things aren't working (like speedo) so I gotta sort that out. All in all, I'm pleased. Makes a lot of boost real quick. Not much lag.
  11. The Following 3 Users Say Thank You to futurevr4man For This Useful Post:
  12. #140
    Looking good Gnate
