Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: Upgrade overkill?
  1. #31
    depends on what you can swing the parts for. if you can find someone selling the hubs, knuckles, rotors, calipers, etc as a package...you might be able to get it for a bit less. of course, spending more money on the project for new hubs, caliper rebuild kits, new brake lines, etc, is probably a good idea.
    p.s.
    anyone got a clue how to get the 10mm nuts loose on the rear lines? i managed to get my fronts swapped out to new connectors & ss lines; but the ss lines for my rears are sitting unused in the cargo trays because i can't get the damn things loose. i'd end up stripping the nut. and that's AFTER trying to use flare wrenches.
    p.p.s.
    anyone else use a zip tie to hold the front brake lines onto their coilovers? just curious...
    Yeah, it really varies. Could be much more.
    Yes I use a zip ties for that in several cars. It seems like alot of aftermarket parts dont have the holders or if you swap parts from model to model they might fit but some lack them too. You can get colored ones online to blend in.
  2. #32
    Quote Originally Posted by Nationalmilkman View Post
    Use a torch to warm them up. Did it all the time at the shop. Works great and I can get anybolt out with the right amount of heat in the right place.
    which i would have tried...if i could get it off the car. i'm not about to apply a blowtorch to something with brake fluid in it. i may be dumb, but i ain't stupid.
    Quote Originally Posted by 92EuroDiamante View Post
    i used some black ones. they're wrapped around the black threaded tube. i hope it will be fine. too bad i installed the connecting tube backwards on the passenger side; but it should be fine...i hope.
  3. #33
    Corunna, IN
    As long as you don't clamp the line off it won't matter and your not trying to melt the line off. Just warm it up to break the rust and then your good to go. Someone back me up on this? Now you would never do it on a fuel line but brake lines are no big deal.
  4. #34
    Fowlerville, MI
    i was able to use "maximum braking" before, as the 225 tires did not outgrip the clamping force of the n/a brakes.
    when i upgraded to 275's, the n/a brakes no longer had sufficient clamping force to outgrip the tires; meaning that stopping distances could have been shortened, had more powerful brakes been utilized.
    /story.
    I'm sorry, but this doesn't make any sense.
  5. #35
    then perhaps you'd better study braking physics 101. if you cannot "lock up" your wheels, then you cannot certify that your brakes are giving you maximum stopping performance. it's just that simple. threshold braking is where maximum stoppage occurs; it is the range immediately preceding lockup. if you cannot achieve lockup with your brakes, you cannot know with certainty where the threshold is.
    i'm not really sure how i can "break" it down any simpler for you.
  6. #36
    Fowlerville, MI
    Yeah, I think that's pointless. If you "can't know" that you're achieving maximum braking, then you're not maintaining your brakes. I'd rather have enough grip that I can't lock up my brakes, then be locking up my brakes all the time.
  7. #37
    The brakes stop the tires, the tires stop the car. If upping the tire width made you lose braking grip then the tires are the problem, not the brakes.
  8. #38
    you are missing it entirely.
    i agree; but that's not the issue i'm dealing with. on ANY car, it is proper (safe/normal/advisable/etc) to have the brakes "outgrip" the tires. ABS was invented so that novice drivers could deal with this condition. it's a normal condition. it's a safe condition. it means that the tire grip is the limiting factor, not clamping force.
    by increasing the contact patch on my car, i found that tire grip was now > clamping force--meaning that i could no longer "lock-up" the brakes. so while it is theoretically possible to stop the car in the same amount of distance as before, it is also probable that the car could be stopped in a shorter distance, should more clamping force be available.
    and that's all i'm getting at. if you keep 225 tires, then n/a brakes will have adequate clamping force to outgun your tire grip. if you increase the contact patch significantly, you can and will benefit from having greater clamping force---but only up until the point at which you can "lock up" the tires. that "point" is different for different vehicles, and primarily varies with size of pads, size and number of caliper pistons, vehicle weight, and tire contact patch.
  9. #39
    Fowlerville, MI
    So your concern is not utilizing all the grip you have by not having big enough brakes. That's fine, but my preference is the other way.
  10. #40
    it's understandable that you wouldn't want to worry about locking up the brakes. but if you set your car up so that it is impossible to do so...how do you know for certain that the maximum extent of pedal that you are equipped with is, in fact, the threshold?
