Results 1 to 1 of 1
Thread: o2 sensor voltage and fuel trim data help!
    Apr 2011
    Hi All
    Hoping someone can have a look at the attached log I pulled today. Its a screen dump of it.
    Basically I have what I think is my narrowband 02 sensor wired up wrong! Need to confirm.
    Car is running 1 x Narrowband 02 to Chrome ECU with the "Dual narrowband Fuel bank trim" option disabled in the ROM because im only using one narrowband o2 sensor.
    I can see I have good voltage for Front Primary O2 sensor (between 0.18 and 0.23) but stupid voltage (constant 4.98 volts) for Rear Primary O2 sensor.
    With the dual narrowband fuel bank trim disabled does this mean the ecu will only use the Rear primary O2 sensor voltage to calculate fuel trim?
    How can I get it to use Front Primary O2 sensor voltage? (do I need to swap wires around on the 02 sensor harness?)
    Below is the data. I am fairly sure this o2 sensor voltage issue is causing my 02 feedback trims to be way out spec?
    Proud owner of
    2nd gen Magna TS 1995
    Twin Turbo 6G72 DOHC,
    FWD 5 speed, Jesters Chrome ECU V2,
    Custom 3" Exhaust, Magnaflow High flow Cat & Muffler, Redback resonator,
    CX Racing FMIC kit, EVO 9 BOV, AEM uEGO wideband,
    Turbosmart Gauge, Tactrix 3 port boost solenoid, K&N FIPK
    MSD 8.5 ignition leads, Apexi 3 bar MAP sensor,
    TJ Magna Clutch Master Cyl, 3SX S/S braided fuel line,
    Montero 482 MAF, Aeromotive 340l , 3SX fuel rail loop,
    VAC delete, Fuel pump hotwire and relay bypass
    GTO hubs and rotors, 4 pot calipers
    Tein Flex adjustable coilovers (tuned for +castor)
    Ride build page on FB
    My Vehicle Garage
