Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Great example of the filth I have to deal with.... Cleaning the Simple way!!
    Your gray water runs into your septic?
    Normally around here only the toilets run to the septic tank. The gray water (sinks, showers) just run somewhere out in the back of the house.
    Never finishes any verified
    Wake Forest, NC
    All drains in my house run into our septic tank. I don't know if it is a state or county code that dictates whether or not gray water can run into the open land. Here in NC it has to go into septic as far as I know. I do have a very large tank. Somthing along the lines of 2000-2500 gallons. I believe they install them larger to accommodate the gray water also. I have to have mine pumped every 4-5 years and it is just the wife and myself in the house. Cost is pretty cheap. $225 to pump the entire tank.
    Seeing that I am also on well water I would not want to contaminate the ground water with chemicals so Even if I wasn't on septic, I still have to be careful what goes into the ground around here.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
