Results 1 to 3 of 3
Thread: Lowering springs Question.
    Nov 2014
    Los Angeles
    Is there a big difference between the Megan and TEIN S springs ad far as quality?
    Sent from my iPhone using Tapatalk
    St.Louis
    Go with the Tein S springs. I ran with megan springs and the rear spring rate was way too high IMO. I am actually running Megans up front and S techs in the rear right now which has been working out great, but just save yourself the hassle and get the S techs. (my sig shows stock rear springs with megans up front on an AWD converted N/a)
  3. The Following User Says Thank You to Bloodlust182 For This Useful Post:
  4. #3
    Nov 2014
    Los Angeles
    Thanks I'm still trying go figure out on the complete look of the car I don't think I'll keep the car after its done
