Results 1 to 10 of 17
Thread: Fastest way to replace alternator?
    So I know how to replace the alternator the snail way of removing your wheel etc, but in this thread a few people claim that it can be done in twenty minutes without removing the wheel.
    http://www.3sgto.org/3000gt-stealth-...ement-how.html
    Conveniently the picture linked that might hint at how that's possible is not working. Can anyone tell me if they know this faster method they were talking about?
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    I leave the bracket and remove only the alternator. People actually remove their wheel for this? Crazy... lol
    Hm I figured it was to get better access to the belt tensioner, but I suppose you could just lift the car and get at it from underneath huh?
    1993 rt/tt Not Verified
    wa state
    Take the wheel off...really?
    I have never pulled a wheel for an alternator, but did the rest as indicated in the thread...
    A/C line loose, pull the fan and the I/C hose is all i ever needed
    STL, MO
    I never had to pull the fan either, intercooler hose, and tensioner. 20 min swap.
    1991 Stealth RT/TT
    wa state
    Quote Originally Posted by Boomer3000 View Post
    Was thinking about this last night, i may have had better luck leaving the bracket on, and pulling the fan...instead of leaving the fan, and removing the bracket. But, its been awhile since I have had to swap one
    Medford OR
    I think the idea of pulling the wheel is for better access to the tensioner and belt. Definitely not necessary, but it would also depend on the tools available.
    I just yank the radiator complete with the fans, makes a bunch of room, and you don't have to worry about raking the alternator across the fins on the way out.
    I'm still on the original 20+ year old alternator!.
    Eagle Lake
    ... I just undo the 3 bolts. It untensions itself. Then pull it out. Put it back in, get belt mostly in then rotate engine to finish putting belt on.
    granted I don't have A/C and I run no tensioner.
    Warner Robins, GA
    And the radiator does NOT need to be disconnected. Even with all the hoses/etc hooked up, just lay the rad on top of the engine.
