Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: Help please. No boost :(
    Quote Originally Posted by ItTricky View Post
    the one on the valve cover is uncapped. still need to get a small filter for it lol. the bubble is capped, and yes we discussed this last year.
    OK ha ha I thought so
    You need something like this, cram it in the intake bubble and pressure test.
    Eagle Lake
    ill make somethin work lol
    one time I made one out of a piece of oak and a jigsaw! billet oak pressure tester. actually worked just fine.
  4. #24
    Eagle Lake
    ive got some fittings i can use.... and a piece of plastic +tape+ clamp works great for plugging a pipe.
  5. #25
    TN
    Remove Mas, put in heavy duty trash bag, put mas back on and clamp. Then use one of the plenum fitting and compressor.
  6. #26
    Eagle Lake
    not a bad idea^^ lol
  7. #27
    TN
    I, personally, haven't used that method... but it has been discussed several times elsewhere. Some people swear by it.
  8. #28
    Jan 2011
    Just start it with the pre-turbo pipes off and see if the turbos are spinning?
    Can't say I've ever personally seen a turbo shaft snap, stranger things have happened though I guess. Sounds like a leak.
  9. #29
    I think he said they were spinning free already.....on the compressor side anyway
  10. #30
    Eagle Lake
    Well. I thought I had it figured out.
    I checked out the turbos. Camera in the exhaust side spin intake side, exhaust side spins fine. So I know they can spin.
    I got everything back together and did a full system boost leak test. Intake mani was leaking first. Fixed that. Re tested. My gauge was reading 15 lbs. With no leaks.
    Thought I fixed it.
    Took it for a drive. No difference.
