Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Turbo SOHC runs 12's
    Seattle
    Quote Originally Posted by MDoe8 View Post
    Do the TT internals fit in these engines?
    Yes but its not necessary unless you want to get away with a sketchy tune The only real upgrade would be the lower compression turbo pistons with thicker ringlands.
    I'm guessing you are 10:1 right?
    8.9 junkyard pistons.
    Quote Originally Posted by sohcstealth View Post
    Sohc ' s are 8.9:1
    Sorta. Early 12 valves in the 80's were 8.85:1 with 1.5mm top rings and full skirts.
    ~1990+ plus 12 valves were 8.9:1 with 1.2mm top rings and a bit more of a slipper design.
    Diamantes in 1992 had 10:1 compression pistons and a little hotter camshaft. I have a set of those in my Fun car.
    Brent - Great Depression Racing
    1992 Duster 11.54@125 22psi BONE Stock 6g72 SOHC 12 valve - -516whp 519ft/lb 20psi (Old 3.13L SOHC built shortblock) - Precision 6765
    Now, Stock 10:1 Diamante 12 valve. Stock heads/cams. Megasquirt 2/E
    1994 Spirit - 12.9@106 - 10psi - Holset He341, stock SOHC 6g72 - 280whp 304ft/lb
    1983 Starlet KP61 -12 point, 4 link, Ford 8.8, 28x10.5, Mopar a904 & 2.5L DOHC 16v, Hx35, A-1000
    https://www.youtube.com/user/GreatDepressionRace
    Andover, MN
    I'm still working on my SOHC, I hope to have a lot of stuff done on it this summer, it's just time and motivation holding it up. I have the right stuff, just need to do work. I fully expect to easily get into the 12s or faster.
    Man this would be so fun to put into a LeBaron
