Results 1 to 4 of 4
Thread: 94 VR4 Spark Issues
    Wilmington
    94 VR4 Spark Issues
    Hello everyone,
    I have returned from the DSM game, back in a 3s! I just bought my buddy's 94 VR4
    Anyways, here's my issue: The valve covers were a little leaky, so I took them off, replaced the gaskets and decided I might as well do the plugs while I'm at it since I'm there anyways. The car had NGK BKR6EIX-11 plugs in it (it was running fine). I did a little research and went with NGK BKR6E-11 plugs, figured it'd be fine. Well, that wasn't the case. It was misfiring at idle, and wouldn't run in gear to save its life.
    So, I put the old plugs back in it (cleaned them off obviously, used dielectric grease on Magnecore wires), and it's running better, but still isn't great. It still has a slight miss at idle. So, I'm thinking I will just put new iridium plugs in it, and see what's up after that. After four years of owning a DSM and not touching a 3s, I can still change all the spark plugs in just about an hour
    I was reading up and got a little confused as to what the gap should be. I read in one thread that the iridiums come gappes at 1.1mm (what the hell is that in comparison to .032?) and I'd like to see if .028 or even .030 would be sufficient. I will be using the iridium plugs again keep in mind.
    Thoughts?
    94 VR4
    95 GSX (Parting out)
    98 Buell S1W
    1.1mm is .043"
    I'd run the gap at .032", but be extremely careful with iridium, it's super easy to break the tip off (same for platinum really).
    Also, I've heard plenty of bad things about magnecore wires.
    Wilmington
    Solid, I'll give it a shot. Thanks man!
    Sep 2012
    Decatur, TN
    I'd ditch the wires, switch to either OEM or MSDs honestly. Have had nothing but good experiences with them.
    If regapping, I've always just used copper plugs and dealt with a short life span. Iridiums were never worth it to me. If you're out in Wilmington btw, there's a pretty active group in Carolina that meets just about once a month. They have a group on FB you could join if you're not already on there, and someone in the group may have an extra set of plug wires you could borrow to test if that cures your problem.
