I'm rebuilding a NA engine and I was planing to put a set of stock 9Bs, its a 93+ NA block so.. no TT oil pan fits there (unless I replace the pump with a 91-92), so.. I was considering 10AN fittings, steel should be the material that will stick to the Oil pan right? So, next question, Can I just weld the returns (steel) and cap those (aluminum cap) until I am ready to put the TT conversion? I dont like the idea of removing the oil pan and all that rtv again lol
I heard that aluminum and steel dont go well at high temps, last thing I want is to leak all the oil in a runing engine lol
That kind of fittings (aluminum on steel fitting) can withstand the oil pressure and temps from the oilpan? both are AN fittings, those shouldnt leak??
