Issue- will run very rich on occasion causing the car to run like crap, loose power, and burn an excessive amount of gas. The problem is that it is intermittent so it will run great for a drive to work 10 miles away then after 8 hours I will turn it on to drive home and it will run rough. Also when I have attempted to drive it home occasionally it will become fixed as I apply more acceleration other times it would just creep all the way back as I cringe. Lately it has gotten worse and runs bad almost every time I start it up.
I just took off the intake, fuel rails, injectors, and all other things needed to access those things off of the car, I thought it was a bad fuel injector but I took a look at those and they all seem to be functioning great. If anyone has some advice it would be greatly appreciated.
