Results 1 to 6 of 6
Thread: can i swap different year radios?
    Mar 2015
    I have a 1991 VR4 with the factory stereo and CD below. it barely works. CAN I put a 97 double DIN in there and use the same wiring harness? will the steering wheel controls still work also? here is a photo of both. thanks for any help or advice.
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    i don't see why not, it should only take 5 minutes to find out! just pop off the bezel and undo 4 screws (and then another 4 for the side brackets) and find out!
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
    Nov 2014
    Los Angeles
    Have u changed the stereo yet?
    Sent from my iPhone using Tapatalk
    Oct 2013
    SW Michigan
    The 91 had a different harness than the 94-2000 harness.
    Nov 2014
    Los Angeles
    Trying to install this one on my 1st gen but cant I.D the wires and finding a diagram is a pain, This was off a 93 but there's no ground
    It probably grounds through the mounting plate.
