Results 11 to 20 of 21
Thread: Unsrpung vs Sprung hub clutches
    VR-3747 :D Not Verified
    Dayton Ohio
    I also had an XTD, and even though they are considered the "Ebay" clutch, mine worked flawlessly as well. Pedal was stiff as hell though. Never felt one that stiff in my life! (giggity!)
    Quote Originally Posted by arm0red1 View Post
    Spec 4+ unsprung thats been modified a littler beefier from rochester clutch and brake in NY.
    Its a bit chattery when you engage it and dont pay attention but I DD it as its not so bad.
    Would probably be even better if i didnt have solid front/rear mounts
    This is the exact setup I have and it's not too bad. It is a bit of an on off switch but you can get acclimated pretty quick. The problem I have is I have the NA slave and master without a booster so the TT clutch is a bit of a bitch. You can see the firewall move out more than a half inch when I press the clutch!
    I sort of miss the sprung clutch but probably what I'm really missing is a clutch booster lol. One thing to consider is I'm sure the un-sprung will be harder on the trans. If you don't like a puck I have a feeling you wouldn't like a FF un-sprung.
    Wrench Monkey Not Verified
    Rochester, NY
    I have one of those sitting on a tool cart in my garage. Tried selling it but no real interest. It's a great setup.
    Was it you or arm0red1 that recommended Rochester? I had contacted somebody on 3si about it. They did a great job.
    I loved my Spec 4+!.
    Now on solid mounts with an OS Giken R3C tripple cerametalic, now that's an interesting drive!.
    August 2010
    Chicago
    Just installed my xtd stage 3 sprung hub...its great. Still breaking it in but pedal feels great.
    34XXlbs..
  8. #18
    Dec 2011
    Iowa
    Quote Originally Posted by NOMIEZVR4 View Post
    Do you have the stock clutch booster? This is the clutch I will be installing in the next month or so.
  9. #19
    August 2010
    Chicago
    Yes i do have the stock booster and it definitely helps.
  10. #20
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Mind explaining the reasoning why it's harder on the trans? Just because there is no cushion on engagement? I was under the impression it would be easier on the synchros if it is lighter (I would assume no springs is lighter).
  • History
  • Information
  • Groups
  • Events
  • Resources
