Oh, and the videos are private!
My daughter writes all the lyrics. She is a bit of a book worm so she is quite impressive when she writes songs. Sometimes I can't believe the stuff she writes. The other kids write the music though.
Pop punk is exactly what they are classified as but I call it pop rock. I normally produce them but this last time I couldn't be there and there were things that bug the hell out of me. Not much but a few things that needed to be there.
I can produce like a mad man but they need a manager. The wife held that job for a while (that's the New York and LA trip) but they really need somebody to take them to the next level.
I played in a 3 piece original band for many years, we were very good. If we had a good promoter we might of done something.
Musically not my cup of tea. However, they've definitely got some talent. Being a drummer myself, I can tell your boy has some pretty good chops already.
I'd make a little trip to listen live. Let us know when they play.
I glanced at the thread title and thought, "Paul's kids post here? what did they do that was so bad?".![]()
www.fairtax.org
