Just sell me the whole car?
I maybe interested in whole car as well!
1991 Stealth RT/TT
Sad to see, looks like was a great car.
I would definitely be interested in selling the whole car, for the right price. Save me a lot of time and effort to strip it down and probably end up stuck with a lot of stuff that won't sell.
CHROMED Clone ECU, ABS delete, FN01R-C rims, ATR DP, test pipe, and exhaust, JIC FTL-A2 struts, PST CFDS, Tial BOV, MSD 8.5mm plug wires, Accelerated Motorsports catch can, Gene's Performance hardpipe kit, TRE FMIC, Denso 550's, IPO dual feed fuel lines, Greddy P/W/H EGT gauge, IPO battery relocation, Kinetic HC-800 battery, 3SX custom radiator, DSM shifter bushings, Saner F/R swaybars, AEM WB O2 setup, SCE StopTech ST-40 332x33 front brake upgrade & 300mm rear rotors, SCE tender springs, SCE caster/camber plates, GT Pro f/r header, DR Billet 650 turbos, forged crank, Crower rods, Weisco 0.40" over pistons, DR Stage 2 heads w/ Ray head lift fix, PM CF seats, 5 pnt harnesses, Quaife front and center LSDs from SCE., KAAZ rear LSD, BC 255 cams, Fidanza adj. cam gears, custom cold air intake, AEM water temp, oil temp, oil pressure gauges.
In for price for whole car, what year was it by the way?
It's a 92. Can't really decide on a price until spring when I'll be able to really look under the hood to see what was smashed and what's still good. Also have to look underneath to check the oil pan, trans and TC housings, and CF DS. Have to make sure the engine can at least be turned over manually. As long as the engine, turbos, trans, and tc are all in good shape, then the car is worth a good bit still. Perhaps the front brakes survived intact as well, or at least the calipers. Need the snow and cold to go away!
Get it towed over to me... we can go through the car inside a heated garage and make a deal?![]()
