Results 1 to 7 of 7
Thread: No start
    Lincoln
    No start
    I have a 91 Stealth TT with a 93 motor in it. It always started and ran fine but now it just cranks and cranks and doesn't start. I think its cold weather induced (old-ish gas). Logging shows the pump runs, ECT reads appropriately, and it has spark. The logger shows injectors are firing. its in the garage now warming up and hopefully it starts. I'm just looking for ideas on anything it could be if it doesnt start once its warmed up. I want your input! Thanks in advance Jake
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    fuel
    air
    spark
    timing
    how old is the gas? when was the last time you actually ran the car? how well is it cranking? is it slow (like you have a bad/cold battery) or is it cranking as fast as normal and just not catching?
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
    Lincoln
    it cranks fine and i put my boost pack on with it too just to help. It ran about 2 weeks ago it was at the body shop and they moved it out of their shed to keep it from getting blocked in. The gas is from August I believe. If it shows rpm and injectors firing that would indicate the cam/crank sensors are working correct?
    Twin Turbo verified
    Melbourne, Australia
    If it has spark & fuel then it will be something connected to the ECU. I believe it won't start if the TPS is unplugged. Will start without the MAF. Not sure about the ISC. Or if timing is way out it won't start. Or it could be the ECU it's self.
    Waiting install
    Build Thread
    Gas isn't old enough to be an issue. I have started cars on gas well over a year old before.
    Your issue isn't related to the cold either. Cold weather isn't going to stop fuel from spraying or spark plugs from igniting.
    Or your ECU is crapping out. Had it happen on a Talon. ECU went haywire and caused the car to dump fuel and it severely fouled the plugs quickly. I literally pulled the plugs and lit them on fire there was so much fuel on them.
    Lincoln
    Changed spark plugs and it fires right up. Wreaked of gas in the plenum. The only thing that makes sense to me is the summer fuel didn't evaporate and my persistence to get it running fouled the plugs beyond all function.
