Results 1 to 8 of 8
Thread: WARNING 3SX Brass shifter bushings are CRAP!
    Had them on my car for 4 years. The inner diameter where it sits on the shifter wears. I had like 1mm of back and forth play in them. No wonder my shifter felt funny.
    They are brass. I should have guessed they would do that. I guess I am going back to stock bushings
    Rollerblade bearings, and fender washers
    Where to buy?
    Amazon, E-bay, local skate shop
    There is a user on a facebook group selling a nice set up made to fit right in the loops.
    Yep, had mine fitted for years with no issues too!.
    Stock is better, you don't feel every little action in the shift sequence.
    If you run the brass ones put a little white grease on the posts.
    I like feeling that.
    Never finishes any verified
    Wake Forest, NC
    I have been running the aluminum ones off of eBay for years now. No play in them at all. I'm pretty sure brass is a lot softer than aluminum so it will develop play after some time.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
