Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Old rusty engine with stuck pistons. Suggestions please!
    lube it up, it always slides easier...
    And the list goes on...
    Why? Because Race Car. verified
    Wichita, KS
    QFT!
    91 R/T TT
    I've done that before with a Morris 1000 motor (950CC)
    Soak the pistons/bore with oil . let it soak. Remove the crank, use a piece of wood on the rods, hit the wood with a hammer, They'll come out.
    The block will be junk though as will the pistons & rods.Well the block will be OK for a rebore but stock bore is always better.
    Steve
    Why would the rods be junk? (Serious question, I like to learn )
    I agree with soaking it in PB Blaster and after sitting a day or two try to turn the crank with a breaker bar.
    Just a curiousity question, but the heads are off right?
    Wichita, KS
    I haven't had time to try anything lately, but I'm thinking PB blaster is probably a good idea. As it sits, the heads are off, the crank, girdle and main seal are off. Just the rods and pistons remain.
    Canaan NH
    Seriously try the acetone mixed with ATF. I read a review stating its the best rust breaker around. It was posted on 3si so I know some of you guys read it as well.
    Seattle
    I (post PB blaster, but I would think Seafoam deep creep would do better) did the crank removal technique plus wood and hammer on a 4 year rust block that sat outside. Problem was the rings were stuck in the grooves, and not just the top groove (if you assumed the piston got damaged. I should have soaked them longer in solvent.
