I'm looking for a base map for the MAP ECU with stock injectors and/or 450cc Injectors.
Anyone still run one of these piggy back ECUs?
Anyone?
There was a base map for the map ecu 2 included with it, not sure about the first version of map ecu.
Mine i bought used. So I'm not sure what's on it currently. They have something listed on the MAP-ECU website, but it dosnt state whether it's and stock or modified MAP.
I know these were never popular in the 3s community. But maybe I'll get lucky.
