Results 1 to 10 of 13
Thread: Swapping to JDM 6 speed....help me check my parts list!
    I have a '93. Naturally a 5 speed.
    I am doing a JDM 6 speed swap
    Currently I have
    Built 6 speed. (locker front diff and bell housing brace installed)
    6 speed transfer case
    6 speed shifter cables
    is that all I need?
    I dont need the shifter housing for the 6 speed, do I? Its my understanding that they are different part numbers but the late-5 speed ones work.
    Also its my understanding I can use the 5 speed driveshaft. yeah?
    Thanks.
    you should be good. You'll know if the shifter box isn't going to work if you can't get into reverse.
    well my car is a daily driver so i sure hope it works.
    Quote Originally Posted by Keyan View Post
    brave man
    anyone else do the swap have some input?
    Don't you need the rear end? Also I'm pretty sure the plate that goes between the engine and trans is different.
    JDM "MR" gears use the 5 speed rear.
    Oh, sorry, missed that.
    Drive shaft?
    fairly certain you can use a 5 speed shaft on a 6 speed transfer case but not the other way around.
