Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Virtual Dyno Software for AEM & Emanage Ultimate (How To & Charts to check out)
  1. #31
    if you are logging on a notebook pay the small fee and get HHH
  2. #32
    -BOOSTTD- verified
    Elko, Nevada, United States
    I suppose I could log on my laptop, but the battery life sucks lol I normally just use my Palm and MMCd. Wait, doesn't TunerproRT have a logging feature as well? I could just log straight off my Maftpro I guess
  3. #33
    Texas
    I completely agree. HHH is DAMN WELL worth the money. I still use it over my Emanage Ultimate logger. The cable is easy enough to make if you have a diode and a 10k resistor and some spade connectors to fit on the pin.
  4. #34
    TunerPro RT does have a logging feature. I used it instead of HHH for use with Virtual Dyno because I can read both boost and wideband (I have the wideband hooked in through the ecu's egrt so HHH can read it but not the boost). But the maft-pro doesn't log on it's own, in order to log you need a laptop connected to you maft-pro. Also, you need tunerpro rt V5 (which is in beta right now) because V4 doesn't log the time at which each sample is taken.
  5. #35
    -BOOSTTD- verified
    thanks for the info I'll have to see what I can do with TunerproRT
  6. #36
    I have done some full pulls and they are now also reading around 1150 HP. Is the sampling rate through my setup just too low? It is half way sane until the RPM data is quite smooth in the upper revs.
    FYI it doesn't look worth it trying to log through the e-manage blue, the claimed sample rate I have seen is only 10 per second!
  7. #37
    Fowlerville, MI
    So, I happened to be looking through a log and noticed that the sampling changes from 20ms to 200ms. I'd imagine if the program was written incorrectly, it would cause the 1000hp issue. Going to look into why it changes in the log some more.
  8. #38
    Huh? verified
    Detroit Area, MI
    BTW for shits and giggles I plotted an aem log that I took on the dyno last week (or was it the week before... time flies). Anyway, they were damn close!
    1993 3ooogt vr4
    Big single turbo and every other mod...
    Powered by BorgWarner
  9. #39
    Man vs 3/S verified
    Kingston, WA
    I have shown 310-330 whp and 340-360 tq.
    Seems a bit high but not unbelievable.
    A dyno program I got for my Droid also said 330 whp, at least they are consistent!
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
