For the EMU, do we type in the fields just what you wrote before the '-' or the entire line?
The info after the dash (not the whole line).
Make sure the O2 1 or 2 and the pressure sensor 1 or 2 are referenced to the correct inputs (IE your pressure sensor could be on 1 with your widbeand on 2 or it could be the flip-flopped...just depends on how you hooked em up).
2011 CTS-V Coupe
So, I'm doing something wrong. It says I have 1163HP lol. AFR and Wideband look right. I'll post the log in a few.
Hopefully this works. The first file is the log I took. I cut out any of the file that isn't 100% throttle.
Graph:
How do I get this to work with my MMCd log files? It's a .csv file, but every time I go to load it in VD it has an error saying "wrong input string" or something of the sort.
The label row (usually top row of CSV) need to be inputted into the options field (File->options)
You sure that wasn't a second gear pull? That's what it looks like.
Pretty sure. Does 5.8sec from 2-6k not make sense in 3rd gear?
