Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Going into open loop way early/high load, low throttle?
    Dec 2014
    Blue Springs, MO
    It was from this thread because I couldn't find anything anywhere else. Actually came from Gump's response.
    http://www.***.org/forum/f1/delphi-5...atency-676642/
    You can link form that site without issue here.
    I had to play with my latencies when I had a scaling issue like that. I ended up having to add across the range to solve it.
    Dec 2014
    Blue Springs, MO
    Ah. Thanks for the heads up. I didn't know. I've never really used this site. I've always used the other.
    Were they that drastically off, though? 430cc instead of 550cc is quite a difference.
    In my case I had 800cc set to 560cc. Used the factory settings which after correcting offsets it ended up closer to the 1000cc factory settings. Like you I could not even get the afr to register from pegged lean.
    Dec 2014
    Blue Springs, MO
    Okay. So, that could be the whole deal right there then, right?
    Can it be confirmed that the settings for PTE/Rochester are the same as Delphi? If that can be determined as fact, using the website below and a little math, I came up with numbers that should be very close to right. And these numbers have higher lag times, so it would richen up the mixture.
    Fuel Injector Lag Time
    I'll probably test it out at least and see if I'm right. I mean, it's not a big deal if I have to scale down like I've done, but I just feel it's cheating.
