I bought this '91 3000gt vr-4 from the auction, 63k original miles. When I drove it home, it didn't overheat, however, it had an oil and water leak from the front side of the engine. My mechanic changed the water pump, front main seal and timing belt (ebay cheapo package), everything ran great for about 200 miles, no leaks. Recently, I took it for a drive and noticed the temp gauge went all the way up to red. Turned the vehicle off on top of a hill and coasted down the hill, all the way home, in neutral.
Novice troubleshooting: I've noticed that the cooling fans don't kick on, even when the temp gauge is at 3/4 to red. Once the temp gauge approaches two or three marks before the red, the cooling fans kick on for about 10 seconds (tops) and turn off. Coolant does get pushed into the overflow tank, and the heater feels cold. From a cold start, if I take the filler neck cap off and observe, I don't see bubbles until the temp gauge approaches about halfway or a little bit more, at that point, the coolant begins to boil, pop and bubble... almost as if the thermostat isn't opening, there is no coolant circulation, and the coolant is just boiling in the system.
Another note: From a cold start, if I let the engine just idle, it won't overheat. As soon as I rev it, or take it out for a drive, that temp gauge will shoot up to the red zone, fast. I don't notice any lack of power, and it doesn't burn thick white smoke, although there is some white smoke coming from the exhaust which looks like condensation. The driver side exhaust provides most of the flow (75%), and exhaust doesn't seem to flow at a very high rate.
I checked all of the fuses under the hood and beneath the driver side dash, they're all good. On the passenger side, I swapped the hi and low fan relays with the horn relay (the horn works), cooling fans still didn't turn on. Pulled the dipstick and took the oil cap off, no chocolate milk from a severely blown head gasket. I replaced the thermostat and refilled the system, still overheats. I have no idea where the coolant temperature sensor is on this vehicle, can someone point out where, and how to get to it? I just don't want to go on a wild goose chase. I've seen stories of guys changing the head gaskets and resurfacing the heads, only to continue to have the same problem. As always, any help is greatly appreciated.
Check it, rule it out.
