That's pretty much a 60k.
The coolant in that area could be from a few sources, your turbo coolant lines are close to there. Before you go off course you need to follow the advice already given. I did not read back through ths again, but I assume you replaced the thermostat or we would not be still discussing this.
A: Pressure test. (tells you you have a leak, but not where)
B: Rent a hydrocarbon tester, or tow to a shop with one. (tells you ifyou have a head gasket issue)
C: Do not assume, or ask what else until you return with these results.
